My ML do not see my audio master after removing the BS 5, while waiting for my Moment to arrive I wanted to use my PC2 .
I thought that this will be a simple 5-minute operation, taking it out from the box ( I have not using it since I bought the BS5 ) and connect to the ML, to mac mini with BMLink and press Nmusic…………nothing.
Probably this is something easy to solve or ??
The PC2 is working when connecting speakers directly to it, the problem is no distribution in the ML.
When I press CD, Radio Amem2 ,Phono, Nmusik, Nradio………..depending on the equipment in the link rooms it should start but nothing.
Any suggestions.
96 Normal 0 21 false false false PL X-NONE X-NONE
G
