You may find the following information helpful:-
For partition walls you also need a plate as below:-
If you get no joy locally ( some dealers can be inexplicably and annoyingly arsey about ordering spares in my experience) I would contact Graham at King St in Manchester. He won't rip you off, and will order you the parts as required.
Graham hasn't worked at King St for a while, he is now selling Land Rovers π
Opman
I'm also trying to find a wall plate for my Beolab 3500 and also what I think is a plastic cover that clips on at the bottom. Can anyone help?
I am assuming you are talking about item 9023 in the diagram below?
Yes that is the piece I need. Thank you for the clarification.
I am the person who sold you the metal wall plate on eBay. Just to let you and other members know that I also have the long screws in pairs, the springs in pairs and the plastic parts available on eBay. I know when most of the Beolab 3500βs are sold they have parts of the wall brackets missing.
I donβt have any more of the metal wall plates available though.
Before you will by these spareparts on ebay please ask your local dealer.
Everything from the wall mout is still avaiable and much cheaper than on ebay.
For example: I bought the metallic mout for the wall where the Beolab is hooked in. This was last september for 11 euros. On ebay the are listet for 30.- Euros. For many sellers parts marked with B&O seems to be 'holy ***' :-)
Ralf
Anyone have a plastic cover for the Beolab 3500? I have the wall bracket, but it looks a bit sad without that lower cover. Can't find anything on eBay.
I can help you out. I have a new and used ones. If you care to contact me at madams2@sky.com I can give you full details.
regards,
Gary
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
