Missing parts for wall mounting Beolab 3500
Hey all,
yesterday I received a mint Beolab 3500 for a very reasonable price, but my problem is that some parts of the wall mount are missing. I knew that before, but the price was so good I couldn't resist the offer.
What I've got is the silver plastic part which is screwed to the Beolab's body and the two allen screws and springs. All the rest is missing.
Who can help out with the part numbers for the parts needed so I can call my dealer to order the spare parts.
Thanks for your help.
Kind regards
Ever heard of a service manual?👍
I already downloaded the service manual, but there are two types of wall mounts mentioned and it's not clear to me which one I need and what minor parts I need too.
3031302 Wall bracket, type 1607
3031235 Wall bracket
3390481 Bag with parts f/Wall bracket
3031333 Wall plate
3390468 Bag with parts f/Wall plate
I'm sure he has Leslie, On this occasion the service manual is not particularly helpful as there is an inadequate description of just what is in the various bags of parts.
You might be better off visiting the dealer and looking at the exploded view on their service spares link.
From what I remember, having had to do this very task some years ago, you could end up with duplicated parts and they are not cheap!
I have no idea what I eventually ordered as much water has gone under the bridge since then.
From your description., I would guess you need :
3031333 Wall plate
WHich is the bit that fixes on the wall and the grub screws to secure it - sounds like you have the parts that then connect to the wall bracket.
Personally, I would take a photo of what you have, go and see your dealer ( or email the pic) and ask for the missing bits to be ordered.
If you get no joy locally ( some dealers can be inexplicably and annoyingly arsey about ordering spares in my experience) I would contact Graham at King St in Manchester.  He won't rip you off, and will order you the parts as required.
joeyboygolf wrote:
.. I'm sure he has Leslie, On this occasion the service manual is not particularly helpful as there is an inadequate description of just what is in the various bags of parts.
You might be better off visiting the dealer and looking at the exploded view on their service spares link. ..
Thanks joeyboygolf 🙂
That's the point. The description is not very helpful. Not all parts are shown with their corresponding numbers.
I'll have a look at the dealer's spare parts list to be on the save side.
Anybody have an idea how much the spare parts are ?
Regards
hey there... i had a beolab 3500 in my house but never used the wall bracket. have since changed it for a wall mounted beosound 8 ! much easier to assemble on the wall.
i have both parts and the bag of screws and spring.  you are welcome to have them for free.
you can email me for any more info.
david
Thanks for your offer david 🙂
I send you a mail.
Kind regards
I've also managed to get my pasws on a Beolab 3500, but am missing the wall mount.
Has any beobods out there got one collecting dust?
Happy to pay a reasonable price and postage
Cheers
Gary
hello martin..hows the beolab 3500 ?
was wondering if you can do me a favour?
there is a posting on here at the moment  called b&o 80% discount , but its for a germany only site it seems.
if i send you the euros , could you buy a white beoplay  a3  and post it to me ?
think it is 103 euro but not including postage. great sounding speaker and very cheap .
what do you think ?
cheers martin
david
