MCP6500 and Beomaster 6500
Does any MCP 6500 work with any Beomaster 6500 without any changes?
Sure.  As would the hand-held remotes 1000/5000/Beo4.
Hi
The short answer is yes, but your Beomaster has to be in option “1” or “2” if it is in option “0” the IR receiver is disabled.
Søren
Thank you both for the quick responses - I should have also asked if there is any special 'pairing' procedure to link the MCP with the Beomaster 6500, and so what are the steps? The reason I ask is that I am trying to get my existing MCP to work with another Beomaster.
Nothing but the Beomaster option setting as mentioned above.
Thanks Martin, how do I get the beomaster into that Option? I have has my system for over 20 years and did not know these options exist.
With the system at standby, press SOUND, 1, STORE, or SOUND, 2, STORE.
I got 2 of those.
Both of them worked fine directly after i placed batteries in them.
Lots of good advices 👍
