mconnect (iphone) white beosound 5
hi, i’ve tried to stream music from my iphone with mconnect to my beosound 5, and the resoults are that when i try to stream something (from tidal) on the besound 5 screen it appears everything but the name of the song stars to light up and light off continusly without reproducing the song, can anyone help me ?
I was able to login to Tidal in the end, and same as you - it doesn't work. The title flashes on the BS5. Im guessing it can't connect. It could be tidal are using https - in which case it wouldn't be able to connect to it with the underlying operating system on the Beomaster5 being so old. The same happens when selecting my beoplay M5 as the Play to destination. However, selecting my Wiim streamer as the destination works.
It might be better to get a behringer UCS202 USB soundcard for the beomaster 5 box and plug a Wiim Mini streamer into it. This will then give you airplay2 and other streaming services including Spotify & Tidal connect (using the tidal app) to the A.AUX input.
