Hello,
I have a MC/MCL converter 1651 whit have the problem that is shutting off after a few seconds. Even the red indicator is going out. It also happens when nothing is connected.
Have anyone a suggestion what could give the problem.
Regards Frans
Hello,
Regards Frans
Probably an amplifier failure or lack of proper source. What is it connected to and how?
Thanks for the replay,
Normally I use the Master link. But it stops also when I do connect anything.
regards Frans
If you have a fully mounted powerlink cable connect it to your master and connect a passive speaker to the MCL. Once you power on the source you should be able to get audio. If it works it could simply be a configuration problem. If you still get nothing, then it may be time for a repair.
