I'm pretty shure it works with a fully wired PL cable, no need for a special one!
@Nico
Connect the MCL2AV to a Beomasters SPEAKER2 output, then check the following voltages in the MCL2AV:
- on the MCL cable white wire you should read approx. 5V (data from Beomaster)
- on the MCL cable pink wire you should read approx. 8V (supply from Beomaster)
- at DC IN (from MCL2P) you should have approx. 15V
If the transceiver LED is still not lit disconnect it and check if you have 5V (where the green wire was connected)
If there's no 5V check the output voltage of both voltage regulators near DC IN socket.
You should read 12V on the first and 5V on the second one.
If there's 12V but no 5V your MCL2AV is probably broken.
