MCL2 AV
I bought a second hand MCL2 AV, but I think it might be broken.
There is a current coming in from my MCL2 P, but I don't see a standby light op the transceiver.
How can I be sure if it's broken or not?
Please help!
You have to connect your MCL2AV to the MCL out of your Beomaster. Powerlink on MCL2AV is an output not input. Did you connect a power suplly to the MCL2AV?
Stefan
I understand what you're saying. That is exactly the way I connected it.
The MCL2AV gets its power from the MCL 2 P, but I don't get a standby light on the transceiver
Can you activate it by pressing the mute button?
Stefan
No
Can you describe how you set it up? Cables, Beomaster....?
If you have a BL 1000 press LINK - 2 -  STORE. Does the LED react?
Does the MCL2P you connected the MCL to work?
Stefan
Setup is cables from beomaster 5500 to the MCL 2 AV. Then powerlink to MCL 2 P.
Transceiver is connected. I don't see an LED at all. The green lead that gives power to the transceiver doesn't give any current.
Sorry, I don`t know what you mean by "the green lead that gives power...".
I don`t think you will get the MCL2P activated by an MCL2AV. You will need a special PL cable with PIN 1 and 4 bridged.
Setup should be: BM5550 -> SPEAKER2 out -> MCL wire -> MCL2AV ( -> IR Transceiver) -> Beolab speaker
MCL2P has an LED which is red in standby and green when activated....(??)
Stefan
Is the MCL-2AV connected to mains? AFAIR it needs it on power supply.
It is connected to the MCL 2 P via a DC cable.
