MCL to ML in link rooms
I just want to share my new experience using the Beolink Converter.
My home has an existing MCL cables to link rooms with MCL 2AV boxes, and I have always thought (also confirmed by many dealers) that I cannot use new link products with ML sockets. Although some logic tells me it should work. So I bought a beolink converter type 1611. And it appears that it works perfectly with new products in the link room. And you can extend to other link rooms with ML cables. Great!
Here is the connections
[MCL2AV] <-7pin cable -> [BeolinkConverter] < -ML cable -> [NewProduct with ML socket]
I have always found it amazing how many different combinations of connections it is possible to make with ML and MCL.
Thanks for sharing!
