I've done something to mess up my MCL configuration :(
I have a BC9300 in the main room with BL8000s; in a family room I have a Samsung TV, with the sound running to the Aux input of the 9300, and speakers in the second room controller with the MCL 2A unit.
For years I've been using my Beo4, press "TV" and it turns on the TV via a Lintronic box, and the MCL turns on the 9300, speakers muted in the main room, and speakers on in the family room.
I had noticed that for some reason pressing the Mute button on the transceiver or remote wouldn't mute the speakers, the red LED comes on for a second but doesn't stay on. So I thought maybe I need to change my set option code on the MCL unit.
So now in the family room turning on an audio source (radio, CD) turns on the 9300 and it plays correctly, but pressing TV does nothing. I have to use my old Beolink 1000 and press AV then TV, then it works. But I never have and don't want to have to press the AV button, because I don't have that on the Beo4.
Another note, when I press (on the Beolink 1000) LINK, 2, STORE, the red LED comes on on the transceiver, but PICTURE 2 STORE or SOUND 2 STORE it does not.
So any suggestions on how to get back to where I was!?
