I want to use a Beolab 3500 as a link room speaker.
Where do I find a cable or connectors to connect it to the beomaster 5500?
I think it should be something like two speaker plugs with an extra pin each.
Best regards Peter
Best regards Peter
You can connect your MCL enabled Beolab 3500 to your Beomaster 5500 using the cables shown below.
They are two speaker type plugs each with an extra pin and on the other end a din plug which goes into the Beolab 3500
Thank You!
Is that B&O part numbers? Does that mean that I can still order them from my dealer?
What site did you get the picture from? An internal B&O site?
/Peter
Thank You
I will call my dealer today.
Out of curiousity. Where did you find the information? It looks like a web-screenshot
/Peter
Hej Peter!
You can only use old BL3500. Since a year or so they only have masterlink inputs. If you have a new one you will need a ML/MCL converter.
Hej Daniel,
I didn't know that. Fortunatelly my BL3500 is quite old. (Mid 90's)
/Peter
never mind
