Masterlink with CAT5: IT WORKS! eh kind of..
ok since my last post didn't get much response maybe this is of interest to people:
I have succesfully got Cat5 linking a BeoVision 7 and BeoSound 3200 (cat5 in walls, with RJ45 wall sockets, with lexcom RJ45 to Masterlink cables connecting the B&O to the wall)
I get full control and it sounds & works great.
However when I try the same with an active kit it don't work at all :(
Any ideas why? what's the difference between the ML in a TV or Hi-fi and the ML in an active/passive box?
I have never played with a Lexcom system, but I would guess as CAT 5 only has 4 pairs of wires meaning 8 wires and MasterLink signals are 9 active wires plus ground then they are likely to have not used pin 3 of the Masterlink which is "ML Sense" which is not used in a lot of products but may well be used in Beolink Active.
I suggest you check to see which wires on the Masterlink cable are connected to the Lexcom system.
A bit tricky as the excom is terminated in a RJ45 meaning its difficult to see what's what when it connects to a wall socket!
I suppose I'm lucky enogh to get the TV and Hi-fi working together. I just didn't realise the active/passive kits were different than the TV and hi-fi's - I though ML was the same !
I'll update if anything improves...
Why not check with a multimeter which pins of the Masterlink are connected to the RJ45.
I notice from the user manual on the web that they use mains earth as their signal return meaning pin 3 is the most likely connection missing.
As I remember CAT 5 don't have a screen used for ground, that very BAD (lexcom cable is CAT 7). 4 pairs is ok because white/blue and pink use the same +5V, when a connection box or original b&o lexcom cable are used. BL active need the ML sense to work.
I am using the Lexcom cables as well. Beolink Passive works.
BUT - I got Cat 7 cabling in the house (ML distribution box in the server room), see pictures in one of my posts.
So, this might be the issue...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
In my previous post to this I mentioned the reason for having all this hassle was because he only had CAT5 and BOSElink cable in the walls.
Well we've managed to convert the Boselink to masterlink 😕
