hi all, I finally have all the equipment I wanted, so I'm trying to set it up.
Situation : Beosound 9000, connected to a Beolab 2 SW, the Beolab 2 outputs are connected to Beolab 8000 pair.
Next to it is a Beovision 7-55 with a Beolab 7-6 centre speaker.
Both devices work, but now I would want to connect them with masterlink to be able to use the Beolab2 & Beolab 8000 as front speakers & suwbwoofer on the Beovision. And of course still use them as speakers whenever I play the BS.
I connected the masterlink cable to the BS & the BV (that's the easy part), but now to what V.OPT option do I set the BV 7-55 and to what A.OPT dp I set the BS 9000 ?
And how do I add the speakers to the list of speakers on the BV ?
How do I make this work ?
