We currently have the following set up: Main room has an Avant with four speakers and sub and a Beosound 3000, Link room 2 has the circular wall mounted ir receiver with volume and on/off and a pair of speakers, link room 3 has a computer and Beoport with speakers.
All of the Masterlink connections are in the main room behind the Avant. In Link room 2 there are two powerlink wires coming out of the wall which are then connected two the two speakers.
When our new BV7 arrives, I want to move the Avant to Link room 2. My problem is when I touch TV on the Beo 4 in addition to activating the Avant, the ir receiver on the wall will receive the signal and also activate TV through the other two speakers in the room. Is there some sort of Option setting I can use to avoid this problem?
Taking it a step further, is there a way I can connect four speakers to the Avant for surround sound but still use the two powerlink wires coming through the wall so that I still have access to netradio/netmusic and the CD player located in the main room?
Thanks!
