Masterlink problem BS9000
I have a Beovision 6-22 which is connected with a masterlink cable to a BS9000. The speakers are connected to the BV. The tv is in option V. Opt 2 and the BS in A. Opt 0.
I had some problems with the cd mechanism of the 9000, and therefore the dealer gave me the opportunity the switch the 9000 for another second life 9000. Installed the new 9000 this afternoonin the same way, but the system does not react when I press cd. It looks like the tv does not see the 9000.
Does somebody know what the problem might be?
Was the BV6-22 equiped with the ML-board? Despite the appearence of the ML socket , it might not work.
Several BS9000's have ML-failures because of an internal faillure. (can be fixed)
Thanks for your info. Ive found the problem. Some of the pins of the 9000 where bent. Dont know how that happened, but the system is now working fine :)
