My aerial freeview picture on BC6-26 seems much better than the master link feed from my sky HD box with the BV7-40. I seem to see the occassional fuzzy lines on the picture. Is this normal?
thanks
Vince
thanks
Vince
Vince,
Do you have a B&O RF amplifier fitted to the RF output on your Beovision 7 ?
yes i do and installed recently
thanks
Had similar problems with fuzzy lines or blinking lines myself. By adjusting the LINK frequency, the lines disappeared. Probably disturbance from something, since changing frequency solved the problem. I had to try different frequencies until I found a compromise between no disturbing lines and good picture-quality.
Morten 🙂
thanks v much keith-the amplifier was attached at the back of the BV7 by my experienced installer so i never touched or even seen the switches but would you expect picture quality better on freeview than on masterlink anyway? I only noticed this after one month of installation-because the red snooker balls are not as bright red on masterlink!😎 Would this interference be also dependent on the sky box and the quality of aerial as well?
thanks
Vince
Vince,
When you are talking about "Masterlink" in your situation you are actually talking about an RF (Modulated signal) over a coax cable.
However your Freeview box is connected via a SCART cable using RGB directly to the Beovision. If you are not getting sharp clear pictures on your link Beovision it is more than likely an issue with the installation of the link RF coax cable or connections with the RF Amplifier.
Correct cable impedance matching and cable quality are so important, even sharp bends in the coax cable can effect picture quality.
Did the installer also fit the RF cable etc ?
sorry-keith a little confused, not very tech orientated. The freeview is actually built in module in BC6. What is 'an RF (Modulated signal) over a coax cable'.?
thanks
Vince,
It does not matter if your Beocentre 6 has the DVB-T built-in as you have or it is via a local STB connected to the SCART, my point remains the same.
Let me explain in more detail:-
So, when you are watching Sky HD on your Beovision 6 via the link, the quality should be very good, but it will certainly be different to the picture from your Freeview (DVB-T) in the Beovision 6.
