Hi
I have just had the following installed, a BeoSound 9000 and BeoVision 5 and a BeoLink Passive.
They are all connected together with Masterlink cable and in seperate rooms each with their speakers attached.
I have a problem whereby if i press CD on the vision 5 i get the CD from the 9000 put it also sends the sounds out the 9000 at the same time. Plus if i then press TV on the 9000 it changes the vision 5 to TV as well instead of leaving it on CD.
It seems like the rooms are not activing independantly of each other. do i need to set something somewhere to say which device is master and what is slave etc.
I am sure this all worked fine until we had a power cut.
Can anyone help its driving me mad.
Andy
