Hi all,
I have a Beosound 3200 which I recently disconnected the masterlink. After reconnecting I can no longer stream to other rooms. If there anything you have to do to get devices to 'resync' to the masterlink network?
James
Hi all,
James
Is there a junction box or cable joint near the master link plug ? If there is open it up to see if anything is disconnected.
Is there enough slack on the cable to see if you are getting a good connection when you plug in ?
Power all devices off - and power them on again....with ML cables all connected.
Hmm, that made the radio start working again after a few minutes, but the TV one still doesn't work.
It's hard to tell whether its just dead or the masterlink isn't connected. What's the next steps for debugging?
As mentioned above: check the junctionbox/es.
make sure all wires are connected properly.
