Masterlink Connection to a DVB HD TV
I have a BV 7-32  in my Bedroom with HDMI and DVB-HD, can I connect my BV7-40 in the Livingroom to that TV so i have Access to the HDMI Ports and the DVB HD Tuner? The BV 7-40 is a MK I TV without HDMI and DVB HD but I love it´s DVD Player.
Unusually you have the 32 with HDMI and the 40 without, had it only been the other way around....
You have the Cinema output (Display 2) connect that to a HDMI converter and run a SCART cable.
FORMAT 0 will then switch between the two displays and you be able to distribute HD video...
Let me know if you get the general idea?
@BEOVOX141
As far as I remember rhe 7-32 with the two HDMI -ins had a VGA-output for the second screen.
Correct me, if I am wrong!
Millemissen wrote:
@BEOVOX141
You are properly absolutely right! So something as simple as this might actually do the trick, since HDCP is not an issue. What do you think?
VGA-DVI adaptor
VGA til DVI-adapter L-Link LL-AD-1115
I get your idea. I also have a vga to hdmi Converter lying around and a 10m hdmi cable.
Can I then control the BV 7-32 via the Beo4 from the Livingroom? What is the scart for? Audio?
BEOVOX141 wrote:
Millemissen wrote:
@BEOVOX141
VGA-DVI adaptor
I have a few of them lying around from earlier on, I guess.
But it won’t help much - VG/DVI carries no sound.....and how about controlling 🤔
VGA is an analog signal - no way to connect to HDMI (which is digital.
Only way (and I would not recommend it) could be use the VGA to a scart converter (connected to one of the scart connections on the 32) and add a sound signal from one of the scart (out) connections on the 7-32.
I see no way to control that from afar.
How about getting a small BVB-HD tv box for the 7-40 instead?
I know, but the original poster mentioned Masterlink so the sound is there, getting it to play might be another matter. I have never had the privilege of meeting a Beovision 7-40 MkI, but I am guessing its possible.
Edit: I did not see your second reply...
Thanks for your Help :-)
I will try a bit with all the possibilities. But I think best is to buy a DVB Receiver for the livingroom. Masterlink is only for audio right?
I have a few of these lying around.
Do you mean one like this:
