Hi Beoworlders,
Have a strange issue with a mlgw that I was hoping someone might be able to answer?
When trying to configure the BV9 in mlgw, it doesn't appear to operate as intended.
After assignment, I register a single Source as DTV and try to simply switch on or off from a virtual button, with no luck. This happens also with the Source set as TV.
The assignment seems to work, switching the device off on registration, but after that, it doesn't seem to want to play ball?
The mlgw audio configuration works perfectly.
My initial thoughts were on addressing. The BV9 seems to have an ML backbone inside it, operating the beomaster5 and beosystem3. It seems that any address I give doesn't work.
Any help greatly appreciated.
