Masterink cable question
Hi guys
Have a problem with the ml cable which needs replaced, the run is prob going to be about 75 mtr, this goes from a master link 8
Splitter all the way round the house up into the loft to another splitter box, need to replace the cable looking at cat6 cable reading on the forums it seems to be possible, question I have is do I use ml to RJ 45 into a jack then cat6 cable round the house to another jack then rj45 to ml then into 8 way ml box, would appreciate your thoughts, on best solution
Hello Kai,
Maybe some useful threads here: /forum/imported-unmapped/masterlink--gt-rj45-cable-what-is-the-right-connector, and: https://beointegration.com/uploaded/EN-BeoLink-handbook-v1-9.pdf
I made two (much smaller) ML networks using Cat7 S/FTP cable and shielded double RJ45 wall outlets (that also act as a local splitter) in my house that work well.
Good luck! Regards,
Johan
