Master Control Panels good or bad?
I was wondering what you think of the Master Control Panels for the 5000/5500/6500 systems.
Good? To big? Clumsy? Do you even use it?
I got a 6500 and it stays on top of the system as a Beo4/Beolink 1000 is way more easy for everyday use.
Does anyone have a spare hinge for a 6500? Acording to the dealer: 3030071 is not aviable anymore here in Denmark.
I quite like my MCP 6500, especially when there are guests around. They always fall into the trap and ask about it then I can go on and on and on about all my B&O ;)
I think they quite nice to use if they are in a place where they don't need to be moved to use them. I do have a Beolink 1000 incase.
Used mine to reprogram a spare Beomaster 6500 today, and they're great for setting up the radio stations quickly, assigning program numbers. And then they belong with the unit.
BTW - tempted today. A white Beosystem (without the CD-player), but with a pristine, white MCP ...
I'm pretty happy with mine - I keep it on my desk and quite often check which radio station is playing, what the time is, and so on... I can't even see the front panels of the actual BS6500 from where I sit most of the time so it's quite useful, even though I have a BL7000 as well, which mostly sits as a display item.
I shelled out more than 100 euros for my white MCP6500 some 1½ years ago, but after I got one of the apparently last sets of new hinges (sorry...), it's pretty darn near perfect. And still on its first set of batteries!
But I don't like the circular volume control. It's really difficult to know where the volume will end up when using it, especially if the IR path is anything less than perfect.
I have to admit to not using mine very much with my 5000 system, though that may be more on account of its location.
I have the stack on top of a dresser in the master. If it were, say in a living room, where the MCP might be on a coffee table... well then I would probably use it more.
The terminal gets 99% of the use.
Only ever used them when I had a couple of Beomaster 5000's that I was selling. Very nice to look at, but I don't know if I would use one on a daily basis. More just to have a play with every now and then.
Craig🙂
I bought my 5000 system purely because of the MCP when it first came out. Incredible for its time. These days I never use my MCP - so much so that I have loaned it out! (By the way , I have the battery cover!) The Beolink 7000 is the ultimate expression of the MCP ethos and is by far the best!
Umm... why wouldn't one have the battery cover? 😁
(apparently I didn't lose mine in the vacuum cleaner though 😳 )
I think they are great in linkrooms, I've had my MCPs (an mcp6500, an mcp7000 and a 5000 (outside of the linksystem)) almost permanently placed on bedside tables and writing desks (where they often get used for telling the time, haha).
At the moment, the mcp5000 is the only one on use (it's used here in my kitchen, where I have a bs5000, not involvred in the MCL system). A bl7000 is permanently placed on my bedside table, great for controlling the loghts in the apartment and when the system is in standby it displays the time (no alarmclock needed :) )
..out of interest, is it possible to use either a MCP 5500 or 6500 with a Beocentre 9500? is there a certain option you would need to set the BC too?
Regards
Ray🤒
