Hello, can this Remote Control used for Beocord 5500 and other 5500? Thanks for helping.
Yes I am using both for a Beosytem 5500, I think the only difference is the mirror finish of the aluminum.
Provided you have the Beomaster of course, since its handling the two way communication.
Yes - if connected to a Beomaster 5500/6500/7000 receiver.
Only the Beomaster has the remote receiver.
It then distributes commands through the signal (datalink) cables.
