Manual wall bracket Beovision 7-40
hi everyone,
Who knows if a manual( NOT motorised) wall bracket for a Beovision 7-32 will fit a Beovision 7-40 ?
it will support the weight? is the bracket smaller or is the same size for both TV's?
thank you
it will not fit, 7-40 is a much larger bracket
I think my local store have one. Tell me if you want me to check it for you.
