bayerische wrote:
I just bought a new Mac mini, and the apple salesman told me to connect it to my TV I only need to get a mini-DVI to video adapter which I got. But my TV shows no picture, it flimmers a bit when I turn the mini on, but then only black. It's connected via a simple video cable and scart adapter to V.tape on the BV5.
Is the problem that it's the first time the Mini is started up?
Cheers
Andreas
I have a mac mini connected to my BeoSystem 3 and it works great. Through adapters, the mini-DVI output go to HDMI input, but this gives picture only. For sound, I use the optical audio out going through a optical-> coax converter, then into one of the BS3's digital audio jack. If you have your BV5 configured correctly to take the HDMI input, the Mac will see it as just another DVI monitor.
If you need more details, let me know and I'll fill in the details after I get home. I live in the US, but don't think that should make much difference in this case, as HDMI is universal.
-- Paul
