My woofer has a slight rubbing in the voice coil. It presents itself at higher volumes. I am looking to replace it. is there a woofer available that is a good replacement?
M75 woofer replacement
I’d try to get it fixed. I found this on a M75 driver that had the foam replaced by an amateur. Found a used replacement driver but all the original driver needed was to have the foam released, properly shimmed and reglued.
