My daughter is having a A9 MkII. She is now thinking on adding a M3 to the mix.
The M3 does not include Spotify Connect of some odd reason.
Will that be a problem in certain use cases?
I assume that it may be a problem in the case one is airplaying Spotify to A9 and want that experience to be expanded to M3, tapping "join" on M3. Correct?
If the builtin Spotify is used I assume there would be no limitations using the B&O app and expanding the experience in multiroom? Correct?
/C
