LX6000 and Commodore VIC-20
I have some problems connecting my Commodore VIC-20 to my LX6000. The Commodore is connected to the TV via an antenna signal, but I can't manage to get the Commodore to show up on the TV. I have another Panasonic TV where I just have to push AV and then it shows up. I am not even sure what to push, I think I have tried almost everything.
Do I need to set up something on the TV before ?
Best Regards
Vifa
You need to tune in to the channel the VIC 20 is "broadcasting" its signal on like it was a TV channel.
Alternatively you can get a video cable like this
I tried to do a search through the frequencies, but I didn't pick up anything ?- will try another modulator then.
I have two places on the back of the TV where I can connect the antenna signal, what is the difference beetween the two ?
the on to use should be marked UHF and VHF.
The other one is probably for an inbuilt satelite reciever (it will be sorounded by a lot of other connectors) and will not be usefull for your purpose
I managed to get it to work now, I appreciate the help, thanks :-)
