L/R balance on BeoLInk Active?
Is there a way to change the left/right balance for the audio output of a beolink active box?  I've seen threads suggest that it's an option on the Beo4 under A.Setup, but I only see menu items for bass, treble and loudness.  I also do not see a "balance" in the "add" list.  Is there some magic that I'm missing?
Thanks,
Stan
When in A.Setup - Bass or Treble, use the left and right buttons on the remote to alter the balance between left and right - something I only found out myself recently
From the user giude (.....but who reads user guides)
In my defense (about not reading the manual), I probably did read it because I *am* a person who often reads the manual, but that was 15 or more years ago when I first bought the system.  Since then, I haven't had the need to tweak the balance until recently.  Also, I think we can all agree that it is rare that a regular B&O user manual provides any useful information.  Contrary to the manul, Andrew's solution works, too (and doesn't require another LIST entry on the remote).
OK, I'm probably protesting too much 😉
Guys, the REAL challenge is: How to reset the values for balance, treble, bass etc. to default / zero! 😁 Nobody seems to know that!?
Agree with TWG, that is the real challenge.
But there isn’t a solution to it.
Some years ago I was in contact with ‘some of the older guys’ in struer, who I supposed could know about that.
Noone did, however - sadly.
