low volume when playing PCM 2.0 on Theatre
Has anyone experienced the issue of low volume when playing PCM 2.0 on Beosound Theatre?
Yes. Low volume on PCM 2.0
Master Optician
You have the latest firmware?
Indeed - I thought the low volume on PCM 2.0 had been solved a couple of SW versions ago?
Remember that when they "fixed 2.0" last year, they somewhat broke DD 5.1 and gave that format a low volume issue.
The recent update - where volume gain can be applied by default per source - was supposed to alleviate the low volume issues generally.
Personally, not noticed 2.0 low volume - while the perceived volume seems quite variable even amongst different 2.o signals, if anything for me 2.0 can if anything be pretty loud in my setup / case.
The issue has been resolved. I foundthat when my streaming device outputs PCM 2.0 audio without CEC enabled, the device itself has a separate volume control. By adjusting the volume to a normal level using its remote control, everything is back to normal.
