Loss of centre channel on BV11
Means - if you set the playback device to decode all sound to PCM, the problem would no occur!?
I have no idea what your talking about, but i'll get right onto it after another glass of red
Finished your glass(es) of red 🍸 ?
Idea was: if the BV11 (sometimes) has trouble with sound in DD5.1 being send from the playback device (PS3) - and not with sound in PCM - all you would have to do is to let the PS3 do the sound decoding (to PCM).
Of cource you would have to change that in the settings of the PS3!
And you would have to do that anyway to have the benefits of the HD-sound formats.
I tried that a few months back when the problem arose, actually a lot of months back.
To be honest i'm so disappointed that this was a know fault all along(not by my dealer may i add), i'm in the process of selling the lot and being done with it all. I don't open the living room door and smile at what is a luxury item to be coveted. I did with my 7-40. I just want the bloody thing gone after the stress and bother it has caused.
I'll keep a few items, but has for B&O that we have owned for on and off for forty years, thats it.
@Hermann_
Of cource the BV11 has the problem - MartinW already described that and that there will be an update for it.
My suggestion was a 'workaround' if using the PS3 (or any nother Bluray Player) - and at the same time the advice to let that do the sound decoding (to PCM) in order to enjoy the HD-sound formats of a Bluray disc.
Of course you would have to change that in the settings of the PS3!
Please check out some of Dr. Mark Waldrep's posts on uncompressed sound.
I wouldn't let a little thing like this put you off the brand , I can assure you mainstream manufacturers suffer even more problems - awaiting s/w updates plus none of them are built like a bno
