Looking for STB Bracket - DVD1 on Avant32
Hello,
I am looking for a bracket/shelf that was made by STB. This is the one that mounts on the top of the Avant32 and forms a shelf. The DVD1 then rests on the shelf, but in a low profile so that the DVD slot is just barely above the top of the Avant.
This is a really great set up for the venerable Avant32. We have an STB bracket on one of our Avant televisions, but the set up in our recent move would be much better for the 2nd Avant32 to also have the same bracket.
Thanks!
Bump
http://m.ebay.co.uk/itm/bang-and-olufsen-stb-dvd-freeview-tv-bracket-/302243151580?hash=item465f187edc%3Ag%3AjyAAAOSwHMJYJfJV&_trkparms=pageci%253Adf6d5b5e-01df-11e7-9c18-74dbd180c999%257Cparentrq%253Aa018e17d15a0a7854ed7e945ffde6176%257Ciid%253A1
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
http://m.ebay.co.uk/itm/Bang-Olufsen-Beovision-Avant-Set-Top-Box-Bracket-manufactured-by-WillsBrothers-/222406247199?hash=item33c872031f%3Ag%3APnAAAOSw4A5YnxnV&_trkparms=pageci%253A70345106-01e3-11e7-8442-74dbd180648f%257Cparentrq%253Aa0303f7515a0a60cea772b0bfffdf708%257Ciid%253A18
Kallasr!
I cannot thank you enough. I had never heard of WillsBrothers, but thanks to you I have now solved the dilemma of the other DVD1 installation. Thank you so much.
You are very welcome.
