Logitech Harmony One Volume Control Issue
Does anyone have an issue with the Logitech Harmony One in controlling the volume on a Beosund?
The remote control works as per the command volume up and down but the volume increase & decrease interval amount is 6 steps instead of the usual 2 steps. So If you are in volume 30,One tap of the Harmony would increase it to 36 instead of 32, I tried playing around in the "Input Delays" setting but to no resolution.
Hi There,
I have the same logitech remote and don't recall having that issue, although to be honest I don't use it often for the BS3000. If I recall correctly in the trouble shooting section on the website that they refer to this 'jumping / skipping' issue and you can 'fine tune' the remote to overcome it. However I'm not sure if this is what you have already done with your input delay settings.
Trust this is of help.
