First og all thank you to Beoworld for the membership.
I've salvaged a MX4000 (type 9150) speakersystem and the corresponding stereo-PCB and want to make it work as a stand alone laptop speakersystem.
I have some experience in the restoration of stereo amplifiers from the 70' and 80', but when is comes to Stereo IC like the LM1876, I lack some knowledge in making it Work.
I've been doing some searching here on the site and found two articles that came pretty close.
#1: first article was on how to salvage the speaker system of an Beovison Avant - which comes down to finding a way to keep the "mute" pin satiesfied.
#2: second article was a dutch article on how to do it for the MX7000 speakersystem - however it has an older stereo-module in the direction of "STK4122" which has slightly more pins.
So now down the MX4000 system.
The Stereo-PCB and speakers worked as they should before salvaging. (=no HW failure expected)
The connectors P31 and P32 goes towards the speakers. (everything is OK there)
The power-in connector P30 is configured as:
Pin1: VCC (A&B)
Pin2+3: Mass connection (common)
Pin4: VEE
I've here connected Pin 1 and 2 to an external power supply @ 21VDC and limited at 300mA
I've measured that the "mute" pin6 and pin11 on the LM1876TF are connected to ground.
And obviously this isn't enough because no sound comes from the speakers.
Question:
#1: How do connect the input voltage at P30 correct in order to accommodate for the -20VDC/+20VDC supply.
#2: Do I need to take some action regarding the "standby Pins" Pin9 & Pin14 - and make sure that the Stereo-power-amplifer becomes active.
any other suggestions are welcome.
Kind regards
Lars
