Lintronic and TiVO HD
Sal,
Have you tried the controlling a different product with the Lintronics box ? You problem could actually be a problem in the Lintronics box.
If you have a second Lintronics box you could also monitor the transmitted IR signal from the first to see what is exactly being sent.
Tivo is in BS3/BV9/BV7mk3 PUC list 🤒
EDIT: You must add it to the PUClist!
Keith,
I fail to see how this problem could be within the LinTronic box ?
Please advise.
" with the TiVOHD remote.
Sal,
I'll be interested in this for the future. I now have Tivo S2 and the Avant controls it just fine. BTW, one day playing, I used a Lintronic to control another Tivo S2 with a Beo4. That worked. I will be replacing one of my Tivos with a S3 soon, so let us know what you discover.
Have you sent the received codes to Michael at Lintronic for further analysis? If you haven't he's always helpful so you may want to try that.
The other option is to download a CCF file for Pronto, import/convert those to Lintronic and see if the behavior is any different.
Michael from Lintronic and I have been exchanging emails today and he suggested a couple of things I try. I haven't yet had a chance to try it yet, but I'm looking forward to reporting on my progress. Probably tomorrow afternoon... I hope it works.
I never knew there were so many nuances to IR codes... BUT... since the your Avant controlled it fine, I am sure that there's a converter solution to be had.
I just can't imagine TiVO to be so "incompatible" as I am initially finding out.
-Sal
I believe that Tivo S3 codes are the same as S2. At least that's what users on the Sling Forums report.
Keep in mind that you'll have to map Beo4 commands directly to Tivo. This can get tricky. I recommend you program a Text mode in Lintronic and then do the mapping. This has worked great for me in order to control the AppleTV. Since Tivo codes are pretty simple, I'm almost certain that you can make this work for you.
Alternatively, you can try using the TV-Menu-Overlay equivalents from the Beo4, but this may get confusing, since you don't have the actual overlay.
And yes, IR can get awfully confusing. Specially Beo4. User simplicity requires system complexity I suppose.
