Linked Room Issue
I have BeoLab 3000 in the link room connected to BeoSystem1 and BeoSound 9000.
PS3 is connected to BeoSystem 1's V.AUX input. PS3 streams music from my PC to the main speakers.
However when I switch BeoLab 3500 in the linked room to V.AUX there is no sound. That is when main room plays music through V.AUX.
Is there anything I'm missing?
BL3500 is reproducing TV sound when set to TV in addition to all other AUDIO sources
Your PS 3 is connected digitally to the BS 1 (?). You will need an analogue audio-signal to distribute it via masterlink to linkrooms.
Stefan
Yes,
I'm using TOSLINK (Optical) cable. Not ready to sacrifice quality to distrubution ability.
Perhaps I can ouput analog audio from PS3 to other input of BS1. That is of course if PS3 able to output 2 analog and digital simultanously
Thanks for the reply!
I`m not sure whether PS3 can play digital and analogue audio simultanously - I don`t think so. But there is a Digital-analogue audio converter from Gefen. It`s not very expensive. Maybe with a splitter this can be a solution. Use an analogue AV-socket as input.
Hope this helps.
Stefan
Stefan,
Thank you for the info!
