I just replaced a BeoVision Avant-32 with a BeoVision 10. The BV 10 is located in a linked room.
My master room has a BV11 connected to a Beosound 9000 using a ML/NL converter. The BV 10 (MK 3) does not recognize the BV11 or any of the sources connected to the BV11 when I use the “Link” button and select the Master Room source. This feature worked fine on the 20 year old Avant.
None of the settings on the BV 11 were changed when I replaced the Avant and all of the BS9000 sources can be operated from the BV 10 in the linked room.
The BV 10 is set on V.Opt.6 (as instructed in the User Guide) and I reset everything. What could I possibly be missing?
Thanks for your help.
