I am about to acquire a Beomaster 6500 and would like some much valued expertise from this forum to help if my suggested additional equipment is sufficient in order to connect this to my existing TV, music and speakers in a link system. I will try to explain how I would like my setup to be in each room and how I thought to go about this project. Firstly my existing equipment is a MX4000 TV and x3 pairs of passive BeoVox CX100.
This is how I would like everything to work:
Main Room: Beomaster (connected to my computers itunes - via the AUX or TAPE2 connection on the beomaster), 2 pairs of speakers that I would like to be able to run all together, or alternately as separate pairs. The beomaster will be situated in a closed cupboard (sorry....sacrelidge to such great design I know) so I guess I would need an eye/tranceiver in this room to be able to control this remotely. What type of tranceiver would I need to get? Could this be connected directly into the Beomaster? If so what type of cable would I need to get hold of? The remote I would use in this room would be either MCP6500, MCP5500 or Beo4.
Room 1: TV (MX4000) and 1 pair of speakers. I would like to be able to control these speakers so they either play the sound from the TV or from the Beomaster. Would it be possible to do this with volume control in this room as well? I'm not sure what type of extra equipment I would need, but for starters I guess I would need an extra "eye" / tranceiver. What type / types of "relay" box ie. MCL2a / MCL2av / MCL2p? Depending on advise, what type of cables would I need to connect? Remote to be used in this room: Beolink1000.
As I understand the MCL system is now replaced by ML. Would I still be able to get hold of MCL cable? In my research I have found a MCL/ML convertor. Where would I be able to purchase these type of cables?
I realise that there is quite a few questions here, but thought to put them all in this post and again would be very grateful for help and advise.
Many Thanks beforehand!
Patrik
