Link Setup Help
Hello. Hopefully somebody can help me.
I have trouble installing my new Beovision 7 with the rest of my masterlinked system.
In my livingroom/kitchen i have a Beosound 9000 (which I want to act as source for radio/cd/a.mem) and a beocenter 6-23 (which I want to act as source for DTV). These products are in the same room.
Now in my tv-room I have a Beovision 7 (which I want to act as source for V.mem/PC/DVD).
How do I set this up. I want to have sound from all sources in all rooms. The cables are drawn, but what v-opt etc do I use?
Cheers
Jonas
If you are a bronze member suggest you upgrade - you cam the download the the Product Configuration guide which will guide you thro' the setup and option configurations
If you are able to view manuals etc just download and use the PCG
Tony
Does it work with mac? If it doesn't, can anyone give me a tip?
/Jonas
Maybe a bit "special", but try a configuration with BV7 as videomaster with V.OPT 2, BS9000 audiomaster with A.OPT 0 and BC6-23 as link TV with V.OPT 6. If you have additional  Beolabs connect them to the TVs.
Stefan
Thanks so far!
Let me rephrase the question like this:
How can I get sound from my Beovision 7 in my tv-room to the Beosound 9000 in my livingroom (and to my other linkspeakers throughout the house).
/Jonas
You can`t get sound from BV7 to your BS9000 in the setup described above, because there are no speakers connected. But you will have sound on your BC6. Just press a source button - V.MEM, PC, DVD. This will work with all other linkrooms.
You will need analogue audio from your mac, because digital sound can`t be distributed via Masterlink. Maybe digital sound works with the newer BV7s....(?)
Stefan
