Link room Speaker to playmaker
Hi Chris,
use this one:
Alternatively find someone to 'rebuilt' your BL3500 (would cost as much or even more).
Is it possible to make a Masterlink converter box? Does anyone have a circuit diagram?
Thanks.
These go for 20 - 30 Euro on Ebay....
... not worth "making" one IMHO.
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I havent seen one on ebay. Thanks :)
Hi ouverture,
hadn't thought of that, when I wrote my post above.
But you are quite right - and it's a rather cheap way of doing it too.
The 1611 simply acts as a driver on the ML.
Greetings Millemissen
Hi Millemissen & Overture.
your right, the 1611 is much cheaper than the almando Masterplay but it's also less comfortable.
With the Masterplay (and its automatic signal detection) you just have to start Airplay and the 3500 plays the music automatically.
With the 1611 you have to activate the 3500 with the beo4, before you can listen to the Airport Express (or to the TV or whatever...)
Thanks!
Indeed - the autosensing of the Masterplay might be worth the higher price!
On the other hand - you'll need the Beo4 for volumen controlling anyway.
