Hello,
I'm currently trying to link my MacBook Pro to my BeoCenter6 - 26 using a DVI to HMDI cable.
It used to work in the past using "PC" on the remote, but not anymore...
It could come from "connections" in the menu which were erased.
Should I use AV1? AV2 ? AV3?
And then, how should I set the preferences?  (Source - Audio - HDTV).
Thanks a lot in advance :)
