I own Beolab 4000's with European specs (220V) but operate them with 110V line voltage (CAN). I currently use an external step-up transformer, which is ok but far away from being a clean setup.
Has anybody modified Beolab 4000 speakers and can advise how to do this? I have no problem with opening the speaker and solder stuff myself.
I had a quick look at the service manual. It appears that the standby transformers can be easily reconfigured for 110V by changing fuses (effectively changing the primary transformer windings from series to parallel circuit).
The manual lists different part numbers for the main transformer. Acquiring a different transformer might be a show stopper. So the question is whether the same main transformer can be used for both 220V and 110V.
Any insight into this is appreciated. Thank you
