Limited Edition "white" colour
The white on my Beogram 8002 type 5635 limited edition has become more yellow and I would like to restore it.
Does anyone know the exact colour that B&O used? A Pantone reference perhaps.
Many thanks Johan,
The wealth of knowledge held on this forum is very impressive. I clearly need to spend more time searching!
Regards
Hi.
If the beolab 8000 system from new was the same color as the sc80.2 stereo bench,i have found a color that matches quite well.
Here you can clearly see the difference
The reason for the big difference is that it was plastik laminate on the beolab 8000 system and the stereo bench was painted,and the paint does not turn yellow like the laminate with time.
Henrik.
Hi BeoFrederic.
Yes you can paint the laminate,just remember to use a plastic primer before painting.
Henrik.
