So I followed link recommendation and just started with an Arduino and some beginners lessons, like blinking LEDs and thermometers with display etc. This to learn how to write code and basic wiring. To the Scandinavian members I can highly recommend link they sell the things but also run a blog with an Arduino school with really good lessons, that in addition to code also touch on topics like basic electronics. So now I’m totally in to this stuff 🤩
Next I started with the IR part of the actual project I want to build, and rather soon run in to problems
From an old LX2802 I have taken the IR receiver, and on the Arduino I tried to get commands both with a library that supports Beo commands and with a code that work with raw IR communication. Not much luck with either, only managed to get two signs of life in receiving raw code right after connecting power to the receiver, not sure if this was actual commands or just errors (😉IR seems to be quite sensitive stuff)
I tried to check that the receiver works at all with a LED and it does glow (pulse) faintly when a bottom on Beo4 is pressed. But with a standard integrated 38kHz receiver connected to the LED it glows constantly and “pulses” when a command is sent. So I started looking through the PCB diagram again, also checking the main PCB of the TV, and there are actually a couple of resistors and a transistor on the signal path also on this PCB before it enters the IC. So I started thinking that it might be that signal I actually want to use as input on the Arduino. Or is it even more missing (is demodulation really done on IC3 on mainboard?) If anyone can help out here, it’s much appreciated?
The Beo command library for Arduino is said to work with the hockey puck receiver from beolink active. But I have a hard time comparing the PCB of that and the LX receiver, if someone can help by looking at these two that’s also a possible way forward.
IR PCB of LX2802:
Main PCB of LX2802 where #138 enters:
Beolink IR receiver for comparison:
Thanks in advance
