Does the Netflix button on a Beoremote 1 work in this combination? Does it start the Netflix app on the LG?
I have BR without the netflix button so I can!'t answer your question. But I can add that the programmable buttons on BR can also be programmed to start the Netflix app. Simply press a programmable button for, I believe, 1,5 second and it will store the current setting to be recalled from that button.
Thank you all for your help!
I was just wondering if it's usefull to add the Netflix version when you have the LG and Stage. Not everyone remembers the function of the preset buttons.
