Hi, I have been trying to find posts that may explain how to integrate an Oled TV into a Beosystem 3 setup, all I want to do is take away the BV4 50" plasma panel and replace it with a 55" Oled TV, I was looking at the Sony Bravia XR A90J. (£2,500)
My problem is I am not clued up on the technical side of cables etc. that I assume I will need to make everything to work together,
I have the Overture CD/Radio, DVD 2, Humax DVR Freesat box, Beo 2 Sub, 8000, 6000 & Beolab 7.2 speakers, I also have the remote wall bracket and the Lutron light panel, at the moment everything works via the Beo5 remote, I also have the Beo 4 remote that can operate most of the system.
So I'm asking for any "detailed" help/information on integrating a good quality 55" Oled TV to the BS3, the reason I'm looking at a 55" is that firstly its a bigger panel but also it fits pretty exact with the width of the BL 7.2
Thanks in advance for any help you can give
