Lg Oled tv + bang olufsen speakers
Configuration
Lg Oled 65 2019 with wisa ready , 4 beolab8000 ( 2 fronts, 2 rears) , beolab 2 sub, beolab 10 (central)
I bought axiim link wisa and 6 beolab receiver 1. I connected my lg tv with wisa connection to all the speakers. It works
The sound quality is ok, but when i connect a beosystem the quality sound is much better.
I would like to buy a beosystem 4 and connect it using trasmitter 1 and receivers to speaskers.
the question is :
how can i send sorround input from my Lg Tv to a beosystem 4 ? Is it possible? How is the quality sound?
do you have any other advise?
I had that ide to. I am going to test a couple of things when my tv arrive. If it does with corona everywhere.
In few days i will try with a beosystem 3 or 4 , i ordered a converter from optical to coaxial. I ‘ ll let you know you if results are good.
Hi Esax,
i tried but it is not possible to have a sorround system with 4K image.
at the moment i ‘ m asking around about Almando sorround Wisa .
Andrea
With either almando or axiim it will obviously sound different as it doesn’t know what speaker are connected (type) and it’s capabilities that are attached to it, as in the speaker profiles. It just takes a, let’s say, bl17 and treats is as a generic speaker. Only b&o has the specific presets preloaded, but with both axiim and almando you can make presets per channel, it’s more work obviously but b&o doesn’t have a 4k capable beosystem atm.
In that way there is little difference between axiim and almando. The axiim looks a lot easier to me though, a mate of mine has done it with axiim and has had great results honestly.
Hi
is it possible to use an HDMI audio splitter, put the audio signal to beosystem 3/4 and video signal to the LG?  This swhould work i think...
Thank you for the advise , the sound difference is impressive between axiim and beosystem.
i would buy a beosystem 3 mk3 or 4
is it possible to send audio from my tv to beosystem 3 or 4 for sorround audio?
I have 4 beolab 8000 (fronts and rears)
beolab 2 sub
beolab 10 center
Hi
HDMI audio to beosystem does not work.
You can only put a monitor screen to the Beosystem 3 or 4. so connect a hdmi -  DVI to system 3 or HDMI - HDMI for montior on system 4.
So only picture will get true there, so you need to connect a google chromecast HD or apple tv true beosystem 3 and 4, use it with puc and control it whole with Beoremote one :)
That will be your best solution.
Cheers, Andreas
Andrea wrote:
Hi
Yes,it does.I am using  Oppo udp203 ,one output into 4k tv, audio ouptut into beosystem3 (mk3).You can use  hdmi splitter from any source,the same way.
