LC2 passive controlHH
Good afternoon,
I have a bose speaker setup in my garden connected to a BS9000 via BL passive with the standard IR eye
what i was wondering was whether it is possible to take the pcb from the Light controller 2 and build it in to a standard switch casing (because it is much smaller than the pcb from the normal IR eye)and use it to control my outdoor speakers instead of the normal IR eye
Best regards
Steven
interesting thought... may i ask what your intent is?
well what i was thinking was rather than 1 of those ugly water proof boxes for the IR eyes i would build the LC2 sensor into a standard water-proof transparent sensor switch that matched my houses switches and sockets.
Regards
You can use a Vishay TSOP 7000. It`s a 455 kHz IR eye and will work with your Beolink passive. It`s about 1 cm x 1 cm small.
Easier and cheaper than your solution. I don´t even know whether an LC2 will work.........I don`t think so.
Available here: http://www.lintronic.dk/InfraRedReceivers.htm - called TT-IR-1455
The IR range is not as good as the original Beo IR eye, but ok. You won`t have the direct volume control, just via Beo4.
Hope this helps.
Stefan
Thanks man that sounds like a good idea i will try and get 1 of those
the LC2 costs about 30€ which was better than the 61€ for the normal eye but if thats cheaper i got to give it a go
