Latest software version BL18 and BLR1
You meant a TR1 (Transmitter 1)You either need a BR1 to update them
Are they automatically updated if they are connected to a transmitter 1?You meant a TR1 (Transmitter 1) BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
Nope - You need to download the software to a USB key and follow a procedure for the TR1 to detect any B&O WISA receiver around and update them if needed. Process is simple, while taking several minutes to complete.I did it several times already without issue.Are they automatically updated if they are connected to a transmitter 1?
The firmware on Beolab's connected via WISA via a TR1 - are NOT updated automatically over-the-air.
There is a firmware update procedure which involves downloading the latest firmware onto aUSB stick, which is stuck into the back of the TRA, re-booting the TR1 into a mode which will send the firmware to the WISA-connected speakers.
It's not for the faint-hearted, as there's no screen on the TR1, so it communicates though a series of coloured/flashing LED states. It takes quite a bit of time too, and if interrupted midway, you can brick your speakers!
If you have a dealer nearby, I'd recommend a service visit for peace of mind.
I was suffering dropouts, and the new firmware fixed it. There's no way of telling what firmware you speakers have without the dealer service tool (I think)
T
B&O recommends at least 1m between a wpl transmitter and a receiver. I guess having two RCV too close may create some issues.That said .... one of my BL18 is less than 1m from my TR1, my other 18 is less than 1m from my 19, my RCV1 are located between 8 and 9m from my TR1, sitting on the floor .... and I have no drops or very rarely on my 18 which are more or less horizontally aligned with the TR1. Moving the TR1 a little bit fixes the drops.I had more issues when i had my WiFi on 5GHz and before the latest BL18 software. I never had drops on my 8000 connecté to the TR1sI’ll try to separate them, maybe they interfere when close together.
Thanks!My 18’s are from late 2018 and guess they have the latest software. Not sure where I can find the version. I will try to have some distance between the RCV1’s as they are now only 10 cm or so separated. I assume they all work with there own private 5Ghz band and need some space on there own. All in all the Wisa protocol sounds very stable based on the feedback. Nice, as I once had the beo wireless 1’s and they were a complete failure.B&O recommends at least 1m between a wpl transmitter and a receiver. I guess having two RCV too close may create some issues. That said .... one of my BL18 is less than 1m from my TR1, my other 18 is less than 1m from my 19, my RCV1 are located between 8 and 9m from my TR1, sitting on the floor .... and I have no drops or very rarely on my 18 which are more or less horizontally aligned with the TR1. Moving the TR1 a little bit fixes the drops. I had more issues when i had my WiFi on 5GHz and before the latest BL18 software. I never had drops on my 8000 connecté to the TR1s BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
