Im planning some long runs from the Theatre to Height Loudspeakers. The "umbilical loom" from the Theatre to everywhere is getting quite chunky and unmanageable.
It seems logical to me that it should be possible to use a couple of long-run flat CAT7 or 8's from the Theatre to wherever you need and terminate as is or with an RJ45 to DIN converter?
I know the BL90 totally works with CAT7 powerlink and with the DPL interconnect so is there a limitation doing the same connecting to the Beolab3?
